ENABLE DES in PTP100 and Check the same
I need help to enable DES on PTP100  & also need the procedure to check whether encryption is in production or not.
Assuming the radio is DES-enabled (some are AES instead) you'd log into the Master/AP end, go to Configuration->Security and enable Airlink Security->Encryption.  There's no obvious way to tell that it's in use IIRC, except that once you've enabled it the link won't come up without DES, so if encryption is enabled and the link is up then encryption was successful.
j
Thanks for your reply. I did the same. But, evidence(Mechanism) is very essential in support  to convince end clients who are sound enough technically. It is also desirable from Cambium end to explain the same.
