Can ePMP-1000 2.4 Ghz radios be set up in a Mesh configuration.
If so, does anyone have detailed instructions on how to accompolish the configuration.
If you’re using the ePMP firmware, then mesh is not possible. If you’re using the ePMP hot spot firmware (which has long since been EOL’d) then I think it supports WDS, and thus you could mesh with that.
I am using the ePMP hot spot firmware. Can someone give instructions on how to set up Mesh with the ePMP hot spot firmware in each ePMP-1000 2 ghz radio?
For instructions on using mesh with cnPilot and ePMP hotspot, check out this document.Wireless Mesh on cnPilot.pdf (501.9 KB)
