ePMP-1000 2.4 Ghz Radio - 802.11 Mode
When configured as an AP, it is my understanding that the ePMP-1000 2.4 Ghz Connectorized Radio can operate in 802.11 mode.
Can somebody confirm that this works?
Does it have the capabilities of running in NAT mode?
Not running the standard EPMP firmware.
In the standard firmware, all AP's are in bridged mode, and you can use "802.11" mode to facilitate a migration from other platform.
If you want to use the EPMP radios  to implement WiFi infrastructure, you can load them with the "EPMP-1000-Hotspot" firmware.
That image will provide you with features commonly used for WiFi deployments, such as having multiple-SSID's, multiple VLANS, and NAT server in the same EPMP connectorized radio used in the  AP-CPE type networks.
https://support.cambiumnetworks.com/files/epmp%201000%20hotspot/
Thanks, Guilherme for the information.
I had pretty well come to the conclusion that the firmware in the ePMP Hotspot radio was different firmware.
I will load the firmware from the link that you sent and if it will works.
I have the latest ePMP-1000 Hotspot firmware loaded and am into the Hotspot.
Can someone directe me how to set up NAT?
Apparently NAT can be enabled/configured. Please download and read the guide. See page 50.
New version Nov. 2016
Saludos
