Hello All,
i have some issues with the ethernet port conguration of ePMP1000, as follows:
- have Cisco switch that ePMP is connected to, with "Auto-negotiate" on both sides (ePMP & Switch)
- port switch is 10/100 BTX, and the only mode that i get is 10Mbps/Full
so i tried the following:
- configure switch port to "Speed 100", "Duplex Full", and the ePMP ethernet port will change to 100/Full for a while then will start coming up n down constantly, till i restore it back to "auto-negotiate"
- configure the port on ePMP to manual, and "100/Full", and the ePMP will start acting crazy, and lost connection totally, i had to rest it to faactory default to get it to work again.
- tried to configure on both sides, but got the same results..
appreciate your help, and thoughts on this one..
