My epmp 1000 intergrated has some problem .detail as bellows. please help me
Before.
1.can’t login with admin/admin after even hard reset( webbase’s showed)
After trying to fix
1.i can login with admin/admin ( sm mode ) after resetting by pluging in and out the power ethernet cable for 4-5 times. But when I change mode to access point then reboot, I can’t access even more ( http to 169.254.1.1 or 192.168.0.1) the webbase config does not show up.
My devices’s using software 3.5.1 and U-Boot 9344_PX 1.1.4.e (Sep 21 2016 - 11:55:11).
before the device can not log in by any account any protocol even after hard reset by hiting on the button
after resetting by pluging in and out.i can login with ID admin/admin, it's performance like normally.i can login by http, telnet.but there's some problem
1.the device work well with SM mode
2.work with mode AP ePTP
3.error happened when i changed to mode AP TDD PTP or AP mode TDD then reboot to apply configuration. i could't login again the webbase did not showed up.(cleared cache on browser)
