Hello all,
Is there any consequence like equipment damage if one disables the “Reset via power sequence” on Cambium force 200? I want to avoid reconfiguring the radio anytime there is a reset caused by power sequence.
Hi @Anunabus2006,
there are no. You will be also able to default the radio with reset button with disabled reset via power.
