Few of our ePMP 1000 v3.5.6 is not responding to on-premise cnmaestro v2.4.1-r10. Any suggestion will help
Start by moving to firmware 4.6.1 and since this fixes many issues yours may be fixed already.
Thanks for your suggestion. We will update few CPEs and check if it’s resolved.
@arefin350
Your link does not look good. RSSI -78 dBm is near no signal at all. After SW upgrade check your alignment and LOS path. Issue can be caused just by packet loss.
