Which is the latest fimrware available to sync epmp 180 to ePMP 3000 AP (ePMP-AC-v4.4.3)
4.4.3 will allow you to sync a f180/200 to a 3000 AP
if you have a mixed environment like I do, you may need 4.5
there are issues with both and for the older N based radios 4.5 is fairly stable compared to 4.4.3
If you are using and f180/200 as a ptp slave, stick with 4.4.3 as in 4.5 the bridge mode looses the management vlan and the radio is not accessable from trunk ports unless your native vlan is your management vlan (which is a major security issue)
Thanks a lot
