ePMP 2.4 and PMP100 collocation
I have two quick questions...
1. When using an ePMP sector in back to back frequency reuse config with a PMP100 sector, what do I need to set the Frequency Reuse option on the ePMP AP. Off, front, or back?
2. The center channels for ePMP 2.4 and PMP100 2.4 do not quite match up. They're all off by .5mhz and on ePMP there are a couple extra channels available on the bottom and top of the band. Is it OK timing-wise to use 2437 on ePMP and 2437.5 on PMP100? This is for 20MHz channel width FCC/US.
Thanks!
Thanks!
we only ran them back to back for a few hours, and it didn't seem to make a diffrence to the PMP 100 when we did it.   the channels don't have to match up perfectly for the sync to work, just need the frames start and stop points to not overlap up so your freq is good.      as long as the colo tool is happy, you should be good to good.
