What are you guys using as an ePMP 2.4 antenna for the non gps connectorized unit for client side? I am in the U.S.A.
Jordan,
I think I read somewhere along the line that they're developing a solution that would be similar to the Force 110 dish for 2.4Ghz radios. I want to say I read Q1, 2015.
That would be awesome. For now the only solution I have found is this http://www.itelite.net/en/Katalog/Cambium-Antennas/
The Cambium panel antenna is a decent solution, but they are all on back order. The SRA antenna is terrible.
Thanks for the update.
