Hello,
I need support on how to configure capacity to clients in ePMP 2000.
This is my first time dealing with this because i have been dealing with point to point not multi point.
It is so urgent.
Hello,
It is so urgent.
In the 2000 AP under Configuration - QOS you enable MIR and create profiles for the download/upload speeds you want to limit to. Then in the SM under Configuration - QOS you assign the number of the MIR profile in the AP you want to use.
