Hello
Is AP ( ePMP 2000 system ) works compatible with the devices SM ( ePMP 1000 Integrated Radio , ePMP Force 180,ePMP Force 110) ?
Hello
Yes, ePMP 2000 is fully compatible with all other ePMP products.
Sriram
Yes, the ePMP2000 is a new generation Access Point, and there is a new Generation Beam-forming Sector Antenna for the Access Point. And it's 100% compatible with and uses the existing ePMP Subscriber Modules (1000, Integrated, Force 180, Force 200). The benefits of better interference rejection and filtering and increased signal gain - those all increase performance and those happen by just upgrading the Access Point and/or Sector antenna (and new firmware of course) so your entire customer base can see benefits by simply upgrading the AP and/or the Sector Antennas.
Is the E2K "Migration ready", in standard 802.11 mode, like the EPMP1000, or in that case a migration would have to be planned in two steps
The ePMP 2000 retains the standard 802.11 capabilities of ePMP 1000.
Sriram
