Anyone could help me in designing a network. It is my first time that i'll be using this solution.
Is it compatible to use ePMP 2000 as my AP and ePMP as SM?
Thank you.
Thank you.
Hey Cy! All the ePMP products are compatible with one another, and all of the products can be used in AP or client roles. Although only the GPS products can be used in sync scenarios.
