Does anyone have or know where to find the detailed specifications for the ePMP3000 and Force 300? I need maximum transmit power, recieve sensitivity and throughput per modulation per channel bandwidth so I can build some radio files for use in Pathloss 5.
ericw,
You can find that information in our capacity planner tool. You can download that here: https://support.cambiumnetworks.com/files/epmp/#r3
I do not see support for ePMP 3000 in the capacity planner you mentioned, only support for ePMP 1000.
