IT IS POSSIBLE TO CONNECT THE N5-360° MIMOSA ANTENNA TO THE EPMP 3000?
yes it is (what counts is the specified working frequency range)
is the pigtail connector different?
I believe you’d use normal RPSMA to N pigtails.
Yes, you need N (on the antenna) to RP-SMA (on ePMP 3000) pigtails (LMR195 would be a good choice)
When connecting the antenna to the AP you need to pay attention to the attachment order of the cables
it can be one of the following 2:
CH0 V
CH1 H
CH2 V
CH3 H
or
CH0 H
CH1 V
CH2 H
CH3 V
Thanks you
