ePMP 3000 AP just stopped working need help figuring out why
CPE’s still connecting to it but can’t access the radio. Ethernet port on switch just slowly blinks about 1 second on one off even when you disconnect radio from power and plug it back in the ethernet port light instantly starts slowly blinking.
Figure radio or cable was bad, climber went up tower with new radio.
Pretty shotty work Cambium…
200ft water tank, no way someone could see this radio at 1am but, it’s mounted below / next to the AOL (the flashing light on top of the tower) and I bet some halfwit was shooting at the light (which they failed to hit).
OH yeah! Those are what I call “speed holes”… although I mostly see them on our field service trucks and road side signs. Typically the more holes the less wind resistance, and allows for faster operation! I’ve never seen someone try to apply this to wireless gear, but if it works for cars, signs, barns, etc. it might also work for radios? :man_shrugging:t2: :laughing:
Ah, perhaps you need to install the T-800 mod?
They did you a favour hitting the smart antenna :wink:
