hello,
Im just looking for ideal range the epmp 3000 and epmp 4x4 MU-MIMO sector antenna can be used for with the force 300- 16 radio?
Thank You
hello,
Thank You
Hello,
It’s always recommended to check with LinkPlanner tool before deployment.
It depends on terrain, regulatory limitations applied for country code you are operating under, etc.
Thank you.
We have a couple 12 mi shots with f300-25 on 3000, one customer as an example has a 67pl on 20mhz DS of 6/6 usually, links do vary but currently has 71/6, but customer has seen over 100 down. Also, unlike 1000, he is able to pull what link test shows
That may be worse for a 16
Thank you! I appreciate the response. i just got my first order of cambium equipment in and look forward to trying it out
