ePMP 3000 radio grounding
Is the 3000 radio meant to be grounded? It looks like there's a spot on the back of the radio for a ground lug but neither the radio or antenna comes with a screw or washer for this spot and the manual doesn't reference it. I know the 2000 has a grounding point so I found it odd that this isn't indicated for the 3000.
You are correct, the hole is for a ground bolt/screw. I belive it's an M5-0.8 6mm bolt/screw but I don't have one handy atm. They said it would start being included at some point.
