The video says "Phillips Screwdriver'' but the images show a T25
Good Catch! That is indeed a T25. Sorry for the confusion!
So do I win a Free ePMP3000 AP with Sector and BeamSteering antenna then? I can message you my address if that would help with the shipping? ;) Think of the 100's of possibly 1000's of hours I've just saved people trying to fit their Phillips screwdrivers into the Torx screws, and not knowing what the problem is! LOL
Is the ground on the back again ?
will this epmp 3000 have a smart antenna too? thanks you!
@David_8 wrote:will this epmp 3000 have a smart antenna too? thanks you!
If by smart antenna you mean an uplink beam steering antenna or BSA, then yes. The exact same BSA used on the ePMP 2000 can also be used on the 3000.
