Just curious of those who have deployed ePMP 3000s with 17db antenna and what kind of distance they are getting out of them? Thanks!
It depends on your allowed EIRP at both sides, noise levels, and desired modulations. The antenna pattern also comes into play depending on topography.
I would also encourage you to play with the LinkPlanner:
https://www.cambiumnetworks.com/products/software/linkplanner/
It provides a scientific way to answer to your question very precise.
Dmitry
