I've noticed a bug in the 3000L APs where if you set the AP to Station, then back to Access Point, the TDD PTP setting is enabled. We've been able to fix this by either downgrading to 4.3.2.1(the last one with the option for PTP), shutting off TDD PTP, then upgrading back to 4.4.1. Also, by the command-line interface, the TDD PTP options are still accessible and can be turned back there.
Although rare, I have seen one customer that has experienced this issue. The resolution was to upgrade both firmare partitions to v4.4.1 (upgrade the firmware twice), and then factory default the unit (via the GUI).
