I’m wondering if the Authentication Failures are referring to failed attempts to connect wirelessly, if they’re referring to failed attempts to log in to the interface, or if they’re referring to both.
Network auth attempts is wireless connection attempts. If it goes up with the failures count then you have equipment that is trying to connect to your ap but does not have the correct wpa password.
