ePMP 425 AP causing issues
I have an ePMP 425 configured as a point to point link. Works perfect most of the time but the last couple of days i have had an issue where the AP (Master) throws packets back out on the network. When i reboot the AP it settles but this has happened a few times. i have disconnected the slave to make sure its nothing on that side of the link but the issue only resolves by rebooting the AP.
any suggestions?
Paul
I’m curious as to what “throws packets back out on the network” means and how you found out it was doing this?
What firmware version are you running? Are you running ePTP mode?
Have you disabled all this stuff on both radios?
