Epmp 4600 GPS
Hi all, just curious about the 4600 and the 6ghz SMs GPS… just looking for some clear info. I have heard that the SM gps is an unprotected usb port, is that true?
Yes, there are a couple things you can find on the interwebs about people using 3rd party GPS receivers at 25% of the cambium price point and them working just fine. It cant be just any old GPS receiver though, there is a certain “type” or model that you must get.
