ePMP AP 2000 firmware upgrade
I bought a new ePMP 2000 AP with software version 3.0-RC21 on both banks.
Are there any mandatory versions that I need to install chronologically to the latest version?
Regards
Hi @zica49,
A step-by-step upgrade is usually required for radios that are already installed in production, to avoid breaking a working configuration. For a brand-new, out-of-the-box radio, you can upgrade directly to 5.10.1 before applying any configuration.
If you have an old N radio that has been in production for many years, the recommended upgrade path would look something like: 3.5.6 → 4.5.6 → 4.8.1 → 5.10.1
Thank you!
The device is new in the packaging so I can skip it.
Regards
