I have several doubts in ePMP Best Practices
Hope you can gimme some opinion based on your field experience
QUESTIONS
1. Use TDD mode because Air Fairness Scheduling from Cambium is only available in TDD mode
What is Airtime Fairness
Root Cause:
Slowness of higher data rated client in the presence of slow clients
Resolution:
Airtime Fairness gives equal amounts of air time (instead of equal number of frames) to each client regardless of its theoretical data rate. This will ensure higher download speed to latest devices when slower devices are connected to the same AP.
2. enable Band steering
3. use 40MHz instead of 20MHz chanel width
When using 5GHz, it is recommended to use at least 40MHz channel width, as some client devices may not prefer 5GHz unless it offers a greater channel width than 2.4GHz.
4. HT/VHT
High Throughput(HT)
using VHT40 or VHT80 mode is recommended, as it can allow for better performance.
5. which channel to use for 5GHz
let say now AP1 has clean air on channel 36, but SM1 channel 36 is crowded but channel 37 is not
so I decide to use channel 37 for both AP1 and SM1
But maybe next month channel 37 already crowded and channel 38 is not
How to overcome that problem?
Should I specify just 3 candidate channels?
6. Transmitter Output Power
should I set it to Manual or Auto
7. DHCP Server Below SM
I think DHCP server should reside in AP side instead of SM side because AP side usually in HQ while SM maybe in Branch
HQ has more redundancy than Branch
In what scenario, I should enable this?
8. L2 L3 Firewall
give me a case which L2 L3 Firewall needed
tq
