ePMP: Configuring AP System Location Services
The AP’s System page is used to configure system parameters, services, time settings, SNMP and syslog.  This post looks at the Location Services Attributes.
Location Services
Attribute
Meaning
On-board GPS Latitude
On a GPS Synchronized ePMP radio, the field is automatically populated with the Latitude information from the on-board GPS chip.
On-board GPS Longitude
On a GPS Synchronized ePMP radio, the field is automatically populated with the Longitude information from the on-board GPS chip.
On-board GPS Height
On a GPS Synchronized ePMP radio, the field is automatically populated with the Height above sea level information from the on-board GPS chip.
Use GPS Coordinates
On a GPS Synchronized ePMP radio, the Device coordinates can be populated using the information retrieved from the on-board GPS chip. Click the update.png button to automatically populate the Device Latitude and Device Longitude fields using the coordinates provided by the on-board GPS chip.
Device Latitude
Configure Latitude information for the device in decimal format.
Device Longitude
Configure Longitude information for the device in decimal format.
Device Height
Configure height above sea level for the device in meters.
Device Location
Hyperlink to display the device location in Google Maps
