Power Control |
Transmitter Output Power |
This value represents the combined power of the AP’s two transmitters. This value may be automatically adjusted based on the configuration of the parameter Country. Nations and regions may regulate transmitter output power. For example · 2.4 GHz and 5 GHz modules are available as connectorized radios, which require the operator to adjust power to ensure regulatory compliance. The professional installer of the equipment has the responsibility to
Antenna Gain |
This value represents the amount of gain introduced by an external antenna (minus cable loss). This value is used in calculating the unit’s Equivalent Isotropic Radiated Power (EIRP) level. For certain Country Code configurations, the unit’s EIRP may be limited based on regional regulations. |
Subscriber Module Target Receive Level |
Each SM’s transmitter output power is automatically set by the AP. The AP monitors the received power from each SM and adjusts each SM’s transmitter output power so that the received power at the AP from the SM is not greater than what is configured in SM Target Received Power Level. These automatic power adjustments ensure that the SM is not transmitting excessive energy (raising system noise level) and that the SM is able to achieve an optimal modulation state (and maximum achievable throughput). |
Uplink Antenna Selection |
Uplink Antenna Selection specifies the antenna to be used in the uplink. This parameter is specific to ePMP 2000 APs with optional Smart Antenna. Auto: The AP decides which antenna to use (sector or Smart Antenna) for uplink communications based on internal quality metrics. Forced Sector Antenna: The AP uses the Sector Antenna for all SM uplink communications. Forced Smart Antenna: The AP uses the smart antenna for all SM uplink communications.
