Dear all,
I have realigned the antennas and now we are getting roughly around -61 RSSI at both sides using a 20 MHz channel.
This is a very noisy environment where we have another service provider with several of their APs (5 GHz) installed in the same tower as us.
Also there are 4 other service providers (5 GHz) on a nearby tower about 100 meters from us with their own devices installed.
I have already chosen the best frequency I can find at the moment.
Using the Wireless Test Link, I am now getting around 75/75 mbps (Downlink / Uplink).
Doing some TCP test, I achieved an average about 40/45 mbps (Downlink /Uplink) with peaks about 50/60 mbps.
Why am I getting 25% less throughput than what is being reported in the Wireless Test Link tool?
Now, if I switch to a 40 MHz channel, Wireless Test Link tool averages 90/90 mbps and in a few cases peaked at 170/105 mbps.
Doing some TCP test, I achieved an average about 50/60 mbps (Downlink/Uplink) on the 40 Mhz channel with peaks about 65/75 mbps.
Again, the actual test is some 25% less than what is reported by the Wireless Test Link tool?
However, I observed that using a 40 MHz channel in this environment is susceptible with the connection link getting dropped every 5-10 minutes with the RSSI dropping from -62 dBm to -90 dBm every minute or so.
Will it really be possible in reality to achieve a 75/75 mbps throughput on a 20 MHz channel as reported by the Wireless Link Test tool once I start connecting users behind this backhaul at it’s current state?
Also will replacing the ePMP 1000 radio with an ePMP 2000 radio help?
Any suggestions will be appreciated.
Some Information for the current 20 MHz channel link:
Downlink Packets Per MCS :-
MCS 14 - 64-QAM 3/4 (65%)
MCS 13 - 64-QAM 2/3 (29.9%)
Uplink Packets Per MCS:
MCS 14 - 64-QAM 3/4 (31%)
MCS 13 - 64-QAM 2/3 (57.2%)
AP Side Current RSSI: - 59 dBm (Ch0: -62 dBm, Ch1: -62 dBm)
SM Side Current RSSI: -61 dBm (Ch0: -66 dBm, Ch1: -63 dBm)
Wireless Link Test:
Downlink: 77.997 Mbps
Uplink: 74.785 Mbps
SM Distance: 25.482 KM
RSSI (dBm) Downlink/Uplink: -57/-61
SNR (dB) Downlink/Uplink: 33/34
MCS Downlink/Uplink: 12/14
Downlink Quality: 100%
Downlink Capacity: 80%
Sanay
