The following tables may be referenced for listings of default configuration values for ePMP device parameters.
Each factory default procedure will return the device to the values listed in the tables below.
AP Ethernet Interface, Configuration Defaults
Attribute |
Default Value |
IP Assignment |
DHCP |
IP Address |
192.168.0.1 (Default IP Address) |
Subnet Mask |
255.255.255.0 |
Management Access |
Ethernet |
Ethernet MTU |
1500 bytes |
Port Setting |
Auto-Negotiate |
VLANs |
Disabled |
Spanning Tree Protocol |
Disabled |
SM Traffic Isolation |
Disabled |
DHCP Option 82 |
Disabled |
LLDP |
Enabled(Receive and Transmit) |
AP Wireless Interface, Configuration Defaults
Attribute |
Default Value |
Driver Mode |
TDD |
Country Code |
None / United States / Generic ETSI (ROW / FCC / ETSI device type, respectively) ROW devices do not transmit with Country Code set to None |
Default SSID |
Cambium-AP |
ACS |
Enabled |
Channel Bandwidth |
20 MHz |
Downlink/Uplink Ratio |
Flexible |
Frame Size |
5 ms |
Max Range |
3 Miles |
Max Registrations Allowed |
10/120 (Lite Devices / Full Capacity Devices, respectively) |
Subscriber Module Receive Level |
-60/-55 (ePMP 1000 / ePMP 2000, respectively) |
Downlink Max Rage |
MCS15 |
Management Traffic Rate |
MCS1 |
Colocation Mode |
Disabled |
Synchronization Mode |
Disabled |
Uplink Antenna Selection |
Auto (ePMP 2000 with Smart Antenna only) |
AP Security Parameters, Configuration Defaults
Attribute |
Default Value |
WPA2 Security |
Enabled (default value Cam39-Tai!wdmv) |
L2/L3 Firewall |
Disabled |
Wireless MAC Address Filtering |
Disabled |
SNMPv2 |
Enabled (with default Community Strings) Read-Only Community String – public Read-Write Community String – private Trap Community String – cambiumtrap |
SM Ethernet Interface, Configuration Defaults
Attribute |
Default Value |
Network Mode |
Bridge |
IP Assignment |
DHCP |
IP Address |
192.168.0.2 (Default IP Address) |
Subnet Mask |
255.255.255.0 |
Ethernet MTU |
1500 bytes |
Port Setting |
Auto-negotiate |
Management VLAN |
Disabled |
Data VLAN |
Disabled |
Membership VLANs |
Disabled |
IPv6 |
Disabled |
ARP-NAT |
Disabled |
Disabled |
DHCP Server Below SM |
Disabled |
LLDP |
Enabled (Receive and Transmit) |
Ethernet Port Security |
Disabled |
SM Wireless Interface, Configuration Defaults
Attribute |
Default Value |
Driver Mode |
TDD |
Country Code |
Follow AP / United States (ROW, ETSI devices / FCC devices, respectively) |
Scanning List |
All available frequencies selected for 20 MHz and 40 MHz channel bandwidths |
Network Entry RSSI Threshold |
-90 dBm |
Network Entry SNR Threshold |
0 dB |
Uplink Max Rate |
MCS15 |
Auto (5 GHz SMs only) |
Max Tx Power |
Auto (Automatic Transmit Power Control and Regulatory-controlled) |
SM Security, Configuration Defaults
Attribute |
Default Value |
RADIUS |
Enabled (default EAP-TTLS credentials username: subscriber1, password: cambium) |
WPA2 |
L2/L3 Firewall |
Disabled |
SNMPv2 |
