Epmp Force 100 dish manufactoring Issues
Hi... Here is the solution to my problems...
FIELD SERVICE BULLETIN
SUBJECT: ePMP Force 100 Dish Manufacturing Issues
MODEL / SYSTEM AFFECTED: ePMP Force 100AR5-25 High Gain (25 dBi) SM/PTP Radio
REASON FOR BULLETIN:
Cambium has received reports of manufacturing issues on some of the ePMP Force 100 Dishes. There are two issues that have been reported:
(1) Set screws holes are of incorrect dimension
(2) Set screw holes are misaligned
Distributors are requested to inspect their inventory of dishes for these issues according to the procedure described in this document. If any defects are found, contact Cambium Support and request and RMA for a DOA failure. Defective dish units will be replaced with the new version of the ePMP Force product - the ePMP Force 110. For information on how to contact Cambium Support, please go to:
http://www.cambiumnetworks.com/support/contact-support
INSPECTION PROCEDURE:
See the diagram below for the area of the dish assembly that is impacted. The impacted area is where the set screws screw into the Feed Transition.
regards
Mr. Wilson
ACSP Motorola - Italy
