epmp force 300 on ePMP 1000 and 2000
Hi, I'm having problems and I'll explain which ones.
I'm trying to use the new force 300 on AP 1000 or 2000, AP have version 4.4.3 and also force 300.
It happens that randomly during the day the SM disconnects from the AP.
I have two main mistakes
1) Failed- SM has no allocation on AP
2) SM deregistred - No GPFs from AP.
Check signal level and interference on channell.
This only happens with force 300 because force 200 and 190 remain connected.
Advice or solutions? thank you
jac
Could you please open the ticket with the Cambium Support Team?
https://www.cambiumnetworks.com/support/contact-support/
It's not easy to make any conclusions not seeing statistics, logs, etc.
Thank you.
