At the AP appears a n Alert 17:06:06 GPS firmware upgrade and I don't know where find it.
- NOTIFICACION.docx (196 KB)
Hello Jose,
You need to use the same sw package used to upgrade the GPS Sync unit (for example ePMP-GPS_Synced-v2.3.4.tar.gz). The required GPS fw is included in the package and the device knows how to extract it from it. Please refer to the "AP Software Upgrade Page" section in the ePMP User Guide for the procedure.
Luis
