Is this a known problem? Any SM with NAT mode and DMZ and management interface enabled can't reach CN Maestro.
I'm using 3.5.6 on all my e1k/e2k radios... seems to work fine for me and the cloud version of cnMaestro... what firmware version are you using and are you trying to connect to cloud or on premise?
various, mostly 3.5.1
I forgot to add that the Management Interface is enabled..
Do you mean that you have the Separate Management IP enabled? We do not use this feature.
Our ePMP client radios have a shared WAN/mgmt/NAT IP. I'd suggest updating to 3.5.6 and seeing if the problem persists.
