I am using win8 in laptop. I have upgraded ePMP Integrated Radio Software from version 1.0.3 to 1.1.7. It upgraded successfully but after I reboot this device. I found all signal leds blinking one after another. I can use browse device page in Firefox but i cannot use in STA mode.
What is a solution of this problem ?
LEDs lighting up one after the other repeatedly means that the Station is scanning for an AP. Once it registers to an AP, the LEDs will indicate the receive signal strength with solid lights.
I do not understand the second part of your question where you are not able to use the radio in STA mode. Please contact Cambium support at: http://www.cambiumnetworks.com/support/contact-support. A support engineer will assist you.
i have this same problem on mi force-180 and as you say, in some point the leds come to steady light all 2 (RED/AMBER) or 3 (RED/AMBER/GREEN). But in 3 or 5 seconds the pattern comes back to "SCANING AP".
