Epmp management vlan passthrought ethernet possible?
Hi
I want to manage a 2nd device (ATA) behind the ePMP1000 CPE)
is it possible to bypass the epmp management vlan to the ethernet in order to reach other devices in the same vlan behind the ethernet cpe?
thanks
Antonio
Yes, it’s possible. You have to add Mgmt VLAN ID both to Management VLAN and to Membership VLAN table on CPE.
Thank you.
