ePMP management VLAN
Can anyone help me to understand the difference between these tow vlan management?
Thank you.
Hi NW_WISP,
First management vlan this is DATA VLAN second this is Separate Management VLAN
This is similar as in GUI when SM in NAT mode it has VLAN (Management+DATA), when you enable Separate Management Interface first VLAN used only for DATA traffic, second (Separate Management VLAN) for Management traffic.
For better understanding you can trying change VLANs on GUI and looking to it on CLI. Also it would be great to know your opinion about RADIUS VLAN displaying
Thank you.
We are going to change representation in the nearest future to make it more clear.
Thankk you for your question.
