epmp100 GPS
Using a CMM3 with all ports full with AP’s. Would like to place an epmp1000 on the same tower. Can it be done without connecting to the CMM and just using it’s own GPS sync and not affect the other AP’s?
PS…accidently pressed the 0 on an earlier rating question downward and it went to -1. Didn’t mean for that to happen on the question.
Yes, you can use the onboard GPS and the other APs will work just fine.
