Can i use a ePMP1000 connectorized radio (AP), with a ePMP2000 smart anntena?
@OmarVelez wrote:Can i use a ePMP1000 connectorized radio (AP), with a ePMP2000 smart anntena?
Hi Omar, The BeamForming Smart Antenna is only for the ePMP2000 and ePMP3000 5Ghz Access Points. The ePMP1000 connectorized AP's can use the same Sector Antenna from the ePMP2000, but there is no place for the BeamForming Smart Antenna to connect.
By the way, the ePMP2000 AP's are only about $80 more than the ePMP1000 AP's, with the ePMP2000 LITE being about $285 - and for that you get both beamforming support to mitigate upstream interference, as well as the dynamic filtering to help mitigate nearby channel interference.
Thanks. For the help.
