Hi
Looking for some advise on our first Cambium deployment.
We have 13 E500s installed across a Holiday Park, AP1 is a mesh root, fed via fibre link to core switch.
We have installed an E2000 GPS Sector , also fibre fed and wired back to core switch.
AP9 , AP11 and AP13 all have a Force200 backhaul to the Sector.
Using just AP1 as the Mesh root with the sector disabled the network is coming up , but in multiple hops as you would expect.
However as soon as I enable the Sector to provide the additional egress points , the whole network goes to pot.
Each AP is running Mesh Base, Mesh Client and Guest SSID.
Im guessing I need to enable RSTP somewhere to deal with the mesh links, but I am unsure where I would do this as I dont want to shutdown the backhauls, or the sector, just any rogue inter-ap links.I cant actually work out where I am getting loops from, as each AP can surely only connect back to one AP.
If I disable AP1, and enable the sector with its 3 subscribers nothing much happens - in most cases the APS behind the Force200 dont even come online so it would appear that its the setup of the ePMP2000 that maybe needs to be tweaked.
Any pointers gratefully received, as the mesh guide doesnt cater for multiple egress points on the same SSID..
