I've been looking for this solution all over the web but still I am unable to fix this issue.
If I want to empty a specific field, for example networkWanPPPoEService, what is the command I need to use?
I tried with:
config set networkWanPPPoEService ""
config set networkWanPPPoEService " "
config set networkWanPPPoEService ' '
config set networkWanPPPoEService ''
nothing works.
The software version of my radio is 2.3.3. I know I could update the software version, but I was wondering if there is a command that would work even with this version.
where there is a space between the double quotes. But you also have to save and apply the change, using the commands below.
config save
config apply
For this specific parameter, the 'config apply' will trigger the wireless driver in the SM to restart, so you will lose connectivity to the SM until it re-registers. Once back, the networkWanPPPoEService parameter will be removed from the SM configuration.
Looking at the documentation for this feature, the ability to remove parameters was not added until software version 2.4.1, so for software version 2.3.3, this command was not a supported/valid command. You will need to upgrade to software version 2.4.1 or better.
