ePMP1000 only negociates at 10Mbps,Fix available if cisco switch connected below.
Issue Brief:-
ePMP1000 negociates at 10Mbps only when connecting to cisco switch.
Problem Root Cause:-
POE enabled cisco switchport causes issue.
Resolution:-
In order to resolve this please fix duplex/speed on both radio and switchport,use 100Mbps capable POE,use 100Mbps capable Ethernet cables and disable the power on switchport via interface command "power inline never".
Regards,
Deepesh Chandra Sharma.
Technical Specialist-L3 Networks.
Cisco Certified Network Professional.
Cambium Certified over PMP/PTP/ePMP.
Yes this is correct, before i red this message, we already encountered this problem and corrected it by this same procedure. On our case, it was a problem with managed layer 2 switch.
