I am connecting to snmp through PHP using all the default values.
Version: 2c
Community: public
trying to read the following value: ".1.3.6.1.4.1.17713.21.1.2.30.1.15"
In the device with software version 3.0 works fine, but in software version 3.2 it gives me a timeout.
If I ping to the device is working fine, but the SNMP gives a timeout.
I am comparing one device with 3.0 and one with 3.2 with the exact same configuration, and one is working and the other is not working. I am trying through the command line, using PHP and using a MIB browser.
Version: 2c
Community: public
Maybe someone had this problem and can help.
Thanks!
Could you please check whether issue still persists in 3.3 Release as@dkeltgen mentioned?
