epmp1000 sector antenna broken connector
Hey team,
How can the problem in the attached images be fixed? The antennae is a epmp 1000 90 sector antennae.
Also it cannot be detected by SM which are 1km away from the antennae.
i will appreciate the solutions given
Hello,
The only option is to replace the cables completely, which means disassembling the antenna and replacing the cables from the inside with comparable ones. There is no good, reliable way to re-attach the connectors to the cable.
Regards
