I want to test EPMP1000 connectorized radio on different antennas such as UBNT various sector antennas, RF elements sectors, and some slant dishes. RPSMA on UBNT sectors - Left its is vertical polarisation, Right- horizontal. Do i need to cross RF jumper cables if connect EPMP1000 Connectorized radio? Where is vertical polarization conector on Connectorized radio?
Hello,
You do not and should not have to cross the RF cables. There is no specific "H" or "V" port on the ePMP connectorized radios.
Regards
Ok, do integrated radio automatically "virtually" swaps MIMO chains if its not equal on integrated SM and AP?
This is how MIMO works.
Hello,
Each antenna port connects to virtually identical RF paths and treated as separate antennas. The received signals are internally processed and combined at the RF chip.
Regards
If using a Cambium sector antenna, you will notice the ports on the antenna are labeled "H" and "V". When using the Cambium mounting bracket on the antenna, the placement of the radio is such that the ports in the radio will aligned with the ports in the sector antenna, as depicted on the diagram. This is the way the radio, antenna and mouting brackets were designed to be put together.
Regards
