I am failing to power ePMP200 with my CMM4. Is there a difference between the Cambium cable N000045L001A and the POE Crossover that I stock that swaps 4/5(-) 7/8(+)? David
Hello,
Assuming you already have a 56v power supply connected to your CMM4, the adapter needed is the same used for the 450i AP, which pin-out is given here.
Regards
