Yes. The ideal scenario for co-locating ePMP 2000 Access Points and ePMP 1000 Access Points is to configure both deployments with GPS synchronization. In this case, all receive and transmit cycles are coordinating between both generations of equipment. If the systems are co-located without using GPS synchronization, it is recommended to configure the systems to operate on non-overlapping channels (based on center frequency and channel bandwidth).
