Today my first epmp3000 has arrived and I would like to ask some questions about it
The SmartAntenna: being the sector a Mimo 4x4, it's necessary? do you always use the epmp2000 version? has advantages, in the mode: - 4x4 Multi-User? - 4x2 Single-User? - on customers with F300? - on old customers with F200?
I connected a 2000 series smart antenna but in the web panel it does not appear anywhere that is connected and the BSA LED on epmp3000 radio is off
Another question: Can not select a channel above 20Mhz? Why? I want to try a 40Mhz but there isn't the choice
Right now, the ePMP 3000 does not support the Smart Antenna / BSA. It will in a future software version. Currently 40 MHz is also not available in the software, if I recall correctly.
40 and 80MHz will be available very soon (although 40 will probably be first)... they're working out some disconnect issues with it right now.
ALSO, I didn't notice this when I first posted this, but it appears as though there's a beta that supports 40/80MHz channel sizes... have you tried it yet? It's located HERE.
Today a Force200 (Version: 3.5.5) can't connect to epmp3000 (Version: 4.3.1-RC7)
Also a Force300-16 (Version: 4.3.1-RC7) can't connect to epmp1000 (Version: 3.5.5) Rejected - Incompatible Software Version
Is normal?
Yes, this is normal as the backwards/forwards compatibility firmware has not been released yet. It's in private beta ATM and will be released very soon for public beta.
Another questions: 1 - using epmp3000 sector antenna, what is the max value "Subscriber Module Target Receive Level" to set, to has the best signal and no impact in frequency reuse front-to-back ?
2 - and minimun distance between two sector (Front & Back) ?
3 - and if smart-antenna is used? Same values as question 1/2 ?
Set this to -60dBm
Assuming you're using the OEM antenna, approx 3 feet or 1 meter
The BSA does not transmit, so no changes to the above values.
