Epmp3000L stations dropouts
I honestly wouldn't be surprised if it's something to do with the sm being open to the internet on a public ip. Did you get rid of those?
Yes I did, Nothing has changed. Same dropouts ramdomly.
Hi Guys, an update on this post.
After following recomendations and advices, I had dropped the broadcast on the network to less than 1% and upgraded the radios to 4.5.4rc7.
After more than 1 week I can tell the system is working much better. I still see some ramdom disconnections but not as usual as before. Now most all the rdaios have days of connection uptime.
This is known issue. I am surprised more people aren't reporting. If you enable full log output you should see an error where the SM is being kicked due to an invalid KEY even though they do connect intermittently proving the key is correct. We have this problem with every 3000L we currently have deployed. Cambium is aware of the problem and says it will be fixed in the next FW (Due in the next 30 Days)
That being said we have had to roll back to 2000 radios on some sites until Cambium gets it together.
