ePMP4500 backward compatibility
We recentry replaced a sector from epmp3000 to 4500(8x8 version) all sm are force 300 series except one force 200/25. The force 200 could not been registered. I tried to updated all (sector and SM (200/25 too) to 5.10 and i select Migration mode, without success for 200/25. Any ideas ?
If you can send the Tech Support Files from the AP and the SM that can help us to understand the issue better. Does the SM have the operational channel in the scanning list?
Thanks.
There was a config mistake. I confitm that there is compatibility between old epmp1K and epmp4500 with 5.10 version.
